Hi all,
Does someone have a list of all !%Cx comment type that could be present in Creo trail files
You will find below some examples.
Thanks & regards,
!%CE |
!%CEFeature regeneration failed. |
Guess: ERROR |
!%CW |
!%CWWARNING: EXTRUDE_68 is entirely outside the model; model unchanged. |
Guees: WARNING |
!%CI |
!%CIRegenerating OF02921607-AMO-E17 feature 54 out of 355 ... |
Guess: INFORMATION |
!%CD |
!%CDLine 2 part 7397381: Model changed since mass props calculated. May need to recalculate. |
!%CP |
!%CPWARNING: Design intent is unclear in OF19018856-LAT-E03. Use "Info"/"Geom Check" in Part mode. |
