Export a as IGES
akok
Export a as IGES
My first script in J-link, I will make an export of the part into IGES, but I can't get it to work.
        IGES3DNewExportInstructions igesInstrs;
        GeomExportFlags gef = pfcModel.GeomExportFlags_Create();
        gef.
        igesInstrs = (IGES3DNewExportInstructions) pfcModel.IGES3DExportInstructions_Create(gef);
        model.Export(model.GetFullName(), igesInstrs);
As I can see I need to put in some Export Instructions, but I can't find any info about the GeomExportFlags.
Can you help, or is this the way to go?
Allan Kok
James62
(To:akok)
hi,
Untested code:
Window window = session.GetCurrentWindow();
Model model = window.GetModel();
String modelName = model.GetFullName();
GeometryFlags flags = pfcExport.GeometryFlags_Create();
flags.SetAsSolids(true);
IGES3DNewExportInstructions IGES3DExportInstr =
        pfcExport.IGES3DNewExportInstructions_Create(AssemblyConfiguration
                .EXPORT_ASM_SINGLE_FILE, flags);
model.Export(modelName, IGES3DExportInstr);
James62
(To:akok)
hi,
Untested code:
akok
(To:James62)
Thank you, I get it to work!
