Foldder browser - workspace zoom issues
RH_10122575
Is there a way to set the default zoom value when using the common files - workspace as i keep having to use the mouse wheel to zoom in/out.
TomU
(To:RH_10122575)
According to CS31975, the answer seems to be no.
"Refreshing the embedded page discards the zooming and restores the default setting."
You could try changing your zoom setting for your computer. (That would apply everywhere, not just Creo).
llie
(To:RH_10122575)
Are you using a high definition monitor/laptop screen? We ran into this issue when we first started using HP laptops a few years ago that had really high resolution.
Solution/Workaround:
1.From Creo set the config.pro option, windows_browser_type to “chromium_browser
2.Navigate to C:\Program Files\PTC\Creo 5.0.5.0\Parametric\bin, right click on “Parametric.exe”, Properties
3.From the Properties Compatibility tab, select Change high DPI settings
4.Check the box Override High DPI scaling behavior and set to “System”
