I created an new Format file (.frm) and added there some parameters-links (via Note and &XXXX) with I want to automatically updated from the Main model parameters.
But when I load this Format to my drawing of the model the parameters do not update.
Anyone can give me a hint how to update the parameter-links in the format file according the 3D model parameters?
1.] you have to place a table into format
2.] you have to put ¶mname into table cell
This worked!
Thanks a lot. But it's strange that this is not working inside a Note.
A SessionID or Component ID is required to link a component's parameter or dimension in a note.
See Article - CS20262 to see how.
Toolkit has ProSolidToPostfixId() to get the ID.
Regards, SeonHo CHA.
This behavior is intentional and how formats are designed to work. It helps to remember that the format cannot 'see' the part, assembly, drawing, or anything else. It is a stand-alone object with no dependencies on any other object. If you create a note in the format, the only thing the note will know to reference is itself. Applying a format to a drawing does not copy these notes into the drawing or change their references. They simply continue to exist in the format and display the same thing everywhere. Notes in formats are really only useful for static text or information about the format itself.
Tables are different. These get copied from the format into the drawing, and function as if they had been natively created in the drawing. This means the table is able to reference information from both the drawing and the models contained in the drawing. The drawing has references to its models, so it can display information from them. The format does not. Hopefully that makes sense.
