I can't find the proterty there I can get and set the display style on a part or assembly.
I will like to get the style before I set the style to "No hidden" and then save a tiff file of the part/assembly, and then is the style back.
Can anyone help?
Thank
Allan
I have been trying with:
DisplayStyle.FromInt(DisplayStyle._DISPSTYLE_NO_HIDDEN);
It doesn't give any errors, but it also does not seem to do anything.
Does any have a clue?
Allan
Hi Allan,
did you found a solution to get the current display style?
Marcus
Hi Marcus,
The only way I found was by setting the config option, but it also works.
Allan
Hi
I found a solution.
I got jlink to set the config option Display, like this:
String DisplayStyle = MySession.GetConfigOption("Display"); // get the display style I had
MySession.SetConfigOption("Display", "HIDDENINVIS"); // set No Hidden
do the tiff export like I want
MySession.SetConfigOption("Display", DisplayStyle); // set the display style I had back
Allan
