Hello, I'm trying to access the BOM or component list of an assembly so that I can use it in an import tool for another program.
I see in the otkjavaexamples a ListDisplayedComponents method that returns a list of parts, but I would also need the quantity. Also, this method seems to drill into the BOM structure. I just need the top level assembly parts and their quantities.
I can't seem to find the correct methods or classes to achieve this.
Well... there you go ... I love it when a long term plan comes together.. 🙂
Good Luck - I think you will find CREOSON pretty neat beyond the BOM data.
Dave
This requires quite a few steps to get via Java.... we optimized this in CREOSON (open source automation for Creo) to make it easier... You can call it (amongst other functions ) from Java (or any other language) using JSON transactions via HTTP requests.
Look at the help doc for "bom : get_paths top_level = true"
The JSON response from that you can then process for the quantities with a simple loop.
Alternatively, if you are looking for a more simple tool/way to get data into Excel for comparing/passing to another system.. Nitro-BOM works really well... (note we sell that)
Hope that helps.
Dave
I'll give this a read.
I need to upload the parts to another program via JSON and REST anyway.
Thnaks!
Dave
I can get a session ID in the playground, but get the error "Unable to connect to Creo through J-Link" when giving it a file location.
Does that mean Jlink isnt installed? I am pointed to C:\Program Files\PTC\Creo 6.0.3.0\Common Files
But I do not see a jlink directory. When I installed creo I selected this option:
"Creo object TOOLKIT Java and Jlink"
That does not make sense.... If you can get a sessionID in the playground... you can talk through J-LINK. So that is good!
Can you expand on your "giving it a file location"??? Are you trying to do something outside of the playground? Did you do a "connection : connect" request first to get a new SessionID before making subrequests (e.g. bom: get_paths).
Dave
