I suggest you to open Case at PTC Support, too.
Have you found solution to get the overall_tolerance with new methods?
I just posted a comment on my original post with all the information I've received so far. Unfortunately, all PTC support has said so far is that overall_tolerance is "now part of the value string." Neither they nor I are quite sure what that data point represents, so I still don't know how to extract that boolean from the string.
Here is all the information I've received so far:
General methodology for extracting symbols from the string: https://www.ptc.com/en/support/article/CS280972
List of symbols and ACSII equivalents: https://www.ptc.com/en/support/article/CS282179
Here are the answers I've been able to get directly from PTC support:
• How to parse those value strings to get the same data provided by ProGtoldataPerUnitGet()?
- You’ll need to parse the string and search for respective characters. For e.g. In case of ‘Per unit tolerance’, search for ‘/’ in second or subsequent rows (values returned from API ProGtolCompositeGet()).
• Is it true that ProGtolValueStringGet() returns the exact same string as the first value in the value array returned by ProGtolCompositeGet()?
- True
• Is it true that the primary/secondary/tertiary strings returned by ProGtolDatumReferencesGet() are exactly the same as the first value from each of the corresponding arrays returned by ProGtolCompositeGet()?
- True
• What is the process for parsing the value strings returned by ProGtolValueStringGet() and ProGtoldataCompositeGet() to get the same data provided by ProGtoldataProjZoneGet()?
- Get string returned by ProGtolValueStringGet() and parse it to check if Unicode value of Projected symbol is present and interpret accordingly.
• How do I use the strings returned by ProGtolDatumReferencesGet()/ProGtolCompositeGet() to find the referenced datum objects?
- Get string and parse it to check if names of DFS. Find DFS using ProSolidSetdatumtagVisit () & ProSetdatumtagLabelGet()
• What does the "overall_tolerance" returned by ProGtoldataValueGet() mean and how do I derive that value with the new methods?
- “overall_tolerance” is now part of value string. Not sure its purpose in design. You need to check with design engineer.
• What does the "is_composite" returned by ProGtoldataCompositeGet() mean and how do I derive that value with the new methods?
- ProGtolCompositeGet() should be used.
