3D Copilot question.
For instance during creating an extrusion: I can draw the handle for the depth and it will change by 1mm steps - where can I change the setting to smaller or bigger values/steps than this 1mm?
Additional question - is there an keyboard shortcut to disable the defined grid during drawing the handle?
In 3D CoPilot, bronze arrows symbolize drag direction, while a bronze ring symbolizes rotational direction. 3D CoPilot also features a window with drag value information.
