How to identify the Parallel Datum Plane of a Solid Part Surface.
rkumar-10
Hi
I have to process all the parts in an assembly to export in DXF drawing format.
So, one assembly level drawing will be created with views of Solid Parts.
However i am not sure how to identify the right view or plane.
As most of the solid parts are rectangular plate items. I am trying to get the surface with largest area.
now how to identify this surface is parallel to which Datum plane.
So that i can place a view in Drawing.
If you have a better idea please let me know.
Rakesh
FV
(To:rkumar-10)
Hello all,
Get a surface normal vector and a datum plane normal vector, convert vector coordinates to some common coordinate system, calculate a dot product. The parallel planes will have a value of +/- 1.0.
HIH.
FV.
rkumar-10
(To:FV)
Hi
Can you please share a sample implementation of this?
//Rakesh
