How to move a column in table?
Shumayal
11-Garnet
I am using CREO 10.0.7.0 and on the drawing sheet. I have to edit a bom table .tbl file to modify the template to my needs.
I want to move a column or copy and paste the contents to a new column created at the desired position.  I also want to edit the column width to match text size automatically.
How can I do this task?
Hi @Shumayal,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
Thank you however it appears that basic table functions such as the one that I requested isn't possible in CREO like a word processor or excel. In the end, I just got around the problem by redoing the entire table since moving columns or copying them isn't supported apparently.
