I am new to Creo parametric. As of now, everytime I open a new Creo Parametric session, I have to explicitly register my standalone jlink application through Auxiliary Applications option under Tools menu.
Is there a way to permanently register my application on Creo parametric so that I don't have to do that for every new creo session?
Apoorva
You need to set the config.pro option: creotkdat to point to the path of your creotk.dat or protk.dat file:
https://www.ptc.com/en/support/article/CS283925?language=en&posno=1&q=creotkdat
