How to retrieve model without regenerating using Jlink API
swapnildhengle
8-Gravel
Hi
I am trying to retrieve model, using the API
Is there a way to retrieve model quickly without regenerating
Swapnil
Could you use the "Open Automatic" option .... not sure if there is a JLINK hook for that option (Creo 4 or later) -- but you might be able to send a mapkey to get that to work and get a faster load if there is not.
https://www.youtube.com/watch?v=1rSQChDp7WY
Dave
Minimum data is retrieved in an Automatic representation
Oh - looks like there might be a config.pro option to take advantage of this capability by default which may be useful in your case.
https://www.youtube.com/watch?v=TorxORXyQKA
This Creo Parametric tutorial video covers the changes made to Simplified Reps in Creo Parametric 4.0 (although this video was created using 5.0). Again I am using the PTC World Car dataset, but this time I get to take advantage of the Automatic rep for loading the minimum required dataset. I show
