We are working on building a Creo application using Object Toolkit Java.
One usecase of our application is to execute tasks in background (such as authentication flow, upload opened model) while displaying progress (using animated gifs) on the custom UI created using Creo UI editor.
As per our observation, whenever we start a task in background by creating a new Thread in Java, it blocks the currently open UI dialog i.e the UI dialog completely freezes and doesn't display anything.
The result is same for all modality types for a dialog - MODAL, MODELESS and WORKING.
Sample code snippet:
uifcComponent.CreateDialog(UPLOAD_DIALOG, UPLOAD_DIALOG);
uifcDialog.DialogFind(UPLOAD_DIALOG, UPLOAD_DIALOG).SetModality(DialogStyle.DIALOG_STYLE_WORKING);
uifcComponent.ActivateDialog(UPLOAD_DIALOG);
Thread backgroundThread = new Thread(() -> {
// Background tasks
// Destroy dialog once background task is complete
uifcComponent.DestroyDialog(UPLOAD_DIALOG, UPLOAD_DIALOG);
}, "thread_name");
backgroundThread.setDaemon(true);
backgroundThread.start();
cc: @RJ_11007702
In synchronous you use share the event loop with Creo, even if you would create another thread, you may not called, and by the way this kind of program is not supported by PTC.
You need an asynchronous connection and your own event loop, here you can do what even you like. But even in this mode multiple threads may an issues, it depends which thread tries to do something in Creo.
On top your own event loop may blocked (during EventProcess) on some actions in Creo, for example if the user edit parameters.
That’s all my 2 Cents based on your questions or assumptions 😵💫
Hi @GS_14113977,
Anurag
