How to use TaskId on BaseSession::RegisterTask?
MichelH
Dear Community,
inside OTK Java free I am registering another JLink application using BaseSession::StartJLinkApplication. This works fine. JLinkApplication::IsActive returns true and I can see the registered app in Creo (4.0). Furthermore I can register a task by using BaseSession::RegisterTask. But if I want to excecute the task (JLinkApplication::ExecuteTask) with the same TaskId that I used for registering the task I get a XToolkitNotFound exception. If I want to register another task with the same TaskId I get a XJLinkTaskExists exception.
I do not understand why! I also do not understand why I have to register a task on the BaseSession object but execute it on the JLinkApplication object.
Could anybody help?
Thank you and kind regards
Michael
MichelH
(To:VladimirN)
It got it working now. As a matter of fact the registering of the task needs to happen inside the external application. That's where I got it wrong before. If you are interested see my example code.
The base application executing the task of the external application:
public class ExternalJLinkApplicationLauncher extends DefaultUICommandActionListener {
	@Override
	public void OnCommand() {
		try {
			JLinkApplication externalJLinkApp = pfcGlobal.GetProESession().StartJLinkApplication("externalJLinkApp",
					"com.testing.ExternalJLinkApplication", "start", "stop", "C:\\path\\to\\classfiles", "C:\\path\\to\\textfolder", true);
			String taskId = "externalJLinkApp001";
			Argument dummyArgument = pfcArgument.Argument_Create("dummyArgument", pfcArgument.CreateASCIIStringArgValue("value"));
			Arguments arguments = Arguments.create();
			arguments.append(dummyArgument);
			try {
				externalJLinkApp.ExecuteTask(taskId, arguments);
			} catch (XToolkitNotFound e) {
				System.out.println("Task could not be found in target application.");
		} catch (jxthrowable jxt) {
			System.out.println(jxt.getMessage());
	class ExternalJLinkAppListener extends DefaultJLinkTaskListener {
		@Override
		public Arguments OnExecute(Arguments arg0) throws jxthrowable {
			System.out.println("externalJLinkApp started.");
			return arg0;
The external application:
public class ExternalJLinkApplication  {
	private void registerTask() {
		try {
			try {
				pfcGlobal.GetProESession().RegisterTask(taskId, new ExternalJLinkAppListener());
			} catch (XJLinkTaskExists e) {
				System.out.println("Task " + e.GetTaskId() + " already exists.");
				return;
	public static void start() {
		ExternalTestApp instance = new ExternalTestApp();
		instance.registerTask();
	public static void stop() {
		@Override
			new JwPrintMessage().messageArea("TEST");
			System.out.println("ExternalJLinkApplication started.");
			return arg0;
Thank you all for your support and best regards!
7 REPLIES 7
VladimirN
(To:MichelH)
I found only one article that is at least somehow related to your question: https://www.ptc.com/en/support/article/cs331890
please ask PTC Support.
Martin Hanák
Difficult to understand what happened without a sources.  Could you provide a sample of your code?
MichelH
(To:YaroslavSin)
Thank you all for your replies! I will post the code as soon as I have some time, latest this weekend...
Kind regards
Michael
VladimirN
(To:MichelH)
You're welcome.
MichelH
(To:VladimirN)
	@Override
		try {
			try {
		@Override
			return arg0;
		try {
			try {
				return;
		@Override
			return arg0;
