Is it possible to add a short delay between mapkey commands?
cstarnes
I have an assembly with a lot of program-driven sub-assemblies, so I created a mapkey that launches a regen and then automatically clicks the "current values" for each subassembly. Besides fixing the annoyance of clicking through 20 subassemblies just to complete a regen, it also works from within some excel automation without user-intervention.
The problem is... the mapkey executes the current values clicks faster than Creo can run the programs...so I end up with regen aborted errors. If I step through them manually (even as fast as I can click), there is no problem.
Is there a way to add a few milliseconds of delay between the "current values" commands in the mapkey?
6 REPLIES 6
GabrielZaha
(To:cstarnes)
I think a better way to fix this is to pass the input values from the top level pro-program via the "execute" blocks.
Here is an program example
VERSION 3.0
REVNUM 15
LISTING FOR ASSEMBLY PRO_PROGRAM_EXAMPLE
INPUT
 PARAMETER_1 NUMBER
 PARAMETER_2 NUMBER
 PARAMETER_3 STRING
 PARAMETER_4 STRING
END INPUT
RELATIONS
END RELATIONS
 EXECUTE ASSEMBLY COMPONENT1
 PARAMETER_1 = PARAMETER_1
 PARAMETER_2 = PARAMETER_3
 END EXECUTE
 EXECUTE PART COMPONENT3
 PARAMETER_1 = PARAMETER_2
 PARAMETER_2 = PARAMETER_4
 END EXECUTE
 ADD FEATURE (initial number 1)
 INTERNAL FEATURE ID  2
 TYPE = COORDINATE SYSTEM
 NAME = ACS0
    FEATURE IS IN LAYER(S) :
      20_ALL_FEATURES - OPERATION = SHOWN
      02_ALL_CSYS - OPERATION = SHOWN
 END ADD
 ADD SUBASSEMBLY COMPONENT1
 INTERNAL COMPONENT ID 6
 END ADD
 ADD PART COMPONENT3
 INTERNAL COMPONENT ID 8
 END ADD
MASSPROP
END MASSPROP
In the execute block you map the input prompts from the child with parameters and/or dimensions from the parent.
child_parameter = parent_parameter
By doing this the "Get Input" menu will shown only once.
I use execute commands extensively and pass several top level parameters down to sub-models. Unfortunately, that isn't an option with a large number of parameters, especially with parameters of the same name in a varying number of sub-models.
It complicates things significantly and won't work within the structure of the automation program.
FV
(To:cstarnes)
there is a technique to run a system script.
the script could use 'ping' command - 'ping localhost -n 2 > nul' for a delay.
HIH.
FV
(To:FV)
HIH.
the article picture got disappeared for whatever reason...
here is a link
https://www.ptc.com/en/support/article?n=CS151240&language=en&posno=1&q=system%20script&source=search
RPN
(To:cstarnes)
I can‘t  believe that. My guess is that model regen will run on a sigle thread. If you call an external command, Creo will wait until this finished, doing a sleep command would not help. You may need to wait until the user interface is idle. I would include some dummy picks in the mapkey. But I still think that your program may have an issue. Check your trail file against your mapkeys, you may find commands which where not executed.
cstarnes
(To:RPN)
I didn't think so either, but true story. Creo definitely throws regen errors and doesn't update parameters consistently when stringing together several "current value" clicks in a macro, but works just fine when clicking through them manually. And I see this behavior on multiple machines (running Windows 7).
I solved it by creating a loop in VB (excel program) that runs a macro with a single "current value" click, followed by a short adjustable delay (around 120ms) . Seems to solve the problem. If I go any lower than 100ms or so on the delay, I get the errors.
