J-Link messages file text directory under UNIX
gchampoux
I have just developed my first J-link application (syncronous) in WildFire 3 (M130), and it works fine under Windows XP (and XP x64).
I also need it under UNIX as well (Solaris 10 on a sparc SunBlade 1000).
It does not fail initialization. It's definitely running.
However, it cannot display messages or add menu buttons because it cannot find the messages file.
During initializing, it is supposed to add a menu button and display a success message.
Instead, all I get is this error in the Pro/E message area:
Message 'WIGenMessage' not found in file WIMessages.txt.
When I catch the exceptions for UIAddButton & UIDisplayMessage, the exception message (same for both) is:
com.ptc.pfc.Implementation.pfcExceptions$XToolkitMsgNotFound
This is my protk.dat file:
name wicheckplot
startup java
java_app_class CheckPlotNote
java_app_start CheckPlotTextStart
java_app_stop CheckPlotTextStop
allow_stop true
delay_start false
text_dir /a/ptc_apps/unix/jlink/checkplotnote/text
end
I have also tried setting: text_dir /a/ptc_apps/unix/jlink/checkplotnote
That did not change anything.
My message file WIMessages.txt is in /a/ptc_apps/unix/jlink/checkplotnote/text.
It's contents:
WIGenMessage
%0s
CheckPlotNoteLabel
Check-Plot Note
CheckPlotNoteDesc
Creates the standard Check-Plot note on every sheet of this drawing.
Any advice?
> Gerry Champoux Williams International
> Lead Engineer 2280 E. West Maple Road
> Information Technology Walled Lake, MI 48390
> ' (248) 960-2816 7 (248) 960-2607
> * - * www.williams-int.com
> and it works fine under Windows XP (and XP x64). I also need it under UNIX as well
> ... I get is this error in the Pro/E message area:
> ... My message file WIMessages.txt is in /a/ptc_apps/unix/jlink/checkplotnote/text.
There are many undocumented "rules" for message files. I'm not sure if this is
a rule, but I would suggest that you use all lowercase letters for the file name
of your message files.
Marc
Marc Mettes
Visit My CAD/PDM AutomationBlog
Or, Subscribe to My CAD/PDM Automation Blog by Email
Bingo.
That was it.
After I changed the file name to lower case (and referenced it as such
in the source code) it all worked properly.
Gerry
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
