anyone knows whether there is a keyboard shortcut for switching from the graphic model area to the model tree in the right column? (instead of using the mouse).
(I only know there is a command, the key Q, which hides/shows the right column... there must be also one to do this switching...)
thanks
thank you, that is quite what I was looking for and both the commands you gave me work.
The only thing I am afraid not to be able to do is switching back to the 3d model, but anyway it's a good thing to have already the other way working.
thanks again,
Bye!
