Hello PTC Community,
I hope this message finds you well.
I am working on a project where I need to generate a list of all components and datum planes via WebLink. The list should have three columns:
Column 1: Component name /Datum Plane name
Column 2: All available featureIDs for each component (I have attempted this with pwlMdlFeaturesGet but haven't been successful)
Column 3: Identification of whether it is a datum plane, prt, or asm
Here is my current code:
<script language="JavaScript">
try
if (pfcIsMozilla())
netscape.security.PrivilegeManager.enablePrivilege("UniversalXPConnect");
wpwl = pfcGetScript ();
document.pwl = wpwl;
wpwlc = wpwl.GetPWLConstants ();
document.pwlc = wpwlc;
wpwlf = wpwl.GetPWLFeatureConstants ();
document.pwlf = wpwlf;
catch (err)
alert ("Exception caught: "+pfcGetExceptionType (err));
function WlModelGetBOM() {
var table = document.getElementById("bomTable");
table.innerHTML = ""; // Clear previous content
var ret = document.pwl.pwlMdlCurrentGet();
if (!ret) {
alert("Error retrieving current model");
return;
var modelNameExt = ret.MdlNameExt;
var retDeps = document.pwl.pwlMdlDependenciesGet(modelNameExt);
if (!retDeps.Status) {
alert("pwlMdlDependenciesGet failed (" + retDeps.ErrorCode + ")");
return;
// Create table header
var headerRow = table.insertRow();
var modelNameCell = headerRow.insertCell(0);
modelNameCell.innerHTML = "<b>Model Name</b>";
var FeatureIDCell = headerRow.insertCell(1);
FeatureIDCell.innerHTML = "<b>Feature ID</b>";
var FeatureCell = headerRow.insertCell(2);
FeatureCell.innerHTML = "<b>Feature</b>";
var models = [];
for (var i = 0; i < retDeps.NumMdls; i++) {
var modelName = retDeps.MdlNameExt.Item(i);
var FeatureID = "FeatureID";
var Feature = "Datum/ASM/PRT";
models.push([modelName, FeatureID, Feature]);
// Sort models (by model name)
models.sort(function(a, b) {
return a[0].localeCompare(b[0]);
// Add models to table
for (var i = 0; i < models.length; i++) {
var row = table.insertRow();
var cell1 = row.insertCell(0);
var cell2 = row.insertCell(1);
var cell3 = row.insertCell(2);
cell1.innerHTML = models[i][0];
cell2.innerHTML = models[i][1];
cell3.innerHTML = models[i][2];
</script>
I would greatly appreciate any guidance or suggestions on how to achieve this.
Thank you in advance for your support!
Best regards,
Fred
