Lizenzfehler continuation
mreinthaler
Hi Martin Hanak,
I was not allowed to reply your last answer, so i start a new discussion.
No C:\Programme\FLEXnet Admin License Server\logs does actually not exist on my pc.
When i start the service lmadmin_ptc there comes the following error message...ptc2.PNG
MR
10 REPLIES 10
select lmadmin_ptc service, press right mouse button and open Properties dialog box. On General tab you will find Path to executable item. If this path&file does not exist then license manager has been deleted from your PC and you have to install it again. If it exist then locate log subdirectory, zip it and send me zip file using How to attach file when you Reply to a discussion. procedure.
MH
Martin Hanák
When i want to copy the marked adress and search it in my pc, the adress does not exist.
So i have to install it again ?
you are right, you need to install license manager. Prerequisities for this step are:
  • you need installation DVD (or its copy on harddisk)
  • you need license file
If you do not have both of them, then you are lost .
MH
Martin Hanák
Is only the creo license file enough for you, because i have the installation cd too but it is in school and it may take longer until i have it again?
How should i send you the license file ?
Thanks in advance
you do not have to send me your license file, you can check its contents using information included in this reply.
Before you start FLEXnet installation:
  • go to C:\Programme directory (I think C:\Programme directory is equal to C:\Program Files in German environment) and rename FLEXnet Admin License Server to FLEXnet Admin License Server.OLD
  • remove lmadmin_ptc service
    open Command Prompt window as Administrator
    run the following command
    sc  delete  lmadmin_ptc
    check whether service disappeared from Services dialog box
Your license file contains following lines, please include them in the next reply:
SERVER __HOSTNAME__ PTC_HOSTID=XX-XX-XX-XX-XX-XX 7788
DAEMON ptc_d ...
INCREMENT PROE_Educ1 ptc_d version.0 enddateORpermanent
XX-XX-XX-XX-XX-XX
You can check if this MAC address of network card belongs to your hardware using following commands:
ipconfig /all
-OR-
getmac
After successful check you can proceed with installation.
MH
Martin Hanák
When i key "sc delete lmadmin_ptc" in, there comes "Access denied"
SERVER __HOSTNAME__ PTC_HOSTID=20-6A-8A-9D-1D-CB 7788
DAEMON ptc_d __PTCD_PATH__
INCREMENT PROE_Educ1 ptc_d 34.0 31-dec-2018 1 \
  80E0C030CC774DAE160B VENDOR_STRING="VSVER=2.0 \
  LO=(0,3,6,7,10,14,17,26,32,34,40,45,48,51,52,54,55,56,57,59,60,61,62,63,66,67,69,71,73,74,91,92,93,94,97,100,104,106,108,115,116,125,126,127,128,131,133,134,135,136,137,158,188,191,192,208,213,247,261,262,275,277,278,282,283,291,292,294,324,325,326,327,329,336,347)" \
  SUPERSEDE vendor_info="VIVER=1.0 EXTERNAL_NAME=" \
  ISSUER=PTC-WEB-INSTALL ISSUED=09-nov-2014 \
  NOTICE="HTBLA_HOLLABRUNN, 3120100" SN=8A1391094 \
  SIGN2="0ED3 F9DA 8333 BC02 FE4A 8C7B 09B4 B3D8 0979 \
  0AA6 3C54 0308 763F 05F1 39E3 08BF 9E39 B4EC E4B0 \
  73E5 4367 55F5 979F 2351 ACC6 AA46 9476 0A33 A4EC \
  3E91"
MR
you have to open Command Prompt window as Administrator, this means ... find Command Prompt command, select it, press right mouse button and use Run as Administrator command from context menu.
License file is related to MAC address 20-6A-8A-9D-1D-CB, so you have to check it using commands mentioned in my previous reply.
License is valid until 31-dec-2018 and you can use it to run Creo Parametric 1.0, 2.0 and also 3.0 (because version is 34.0).
ipconfig /all
-OR-
getmac
MH
Martin Hanák
Thanks now i have deleted this service.
I can find the adress here ....
MR
so you can proceed with installation .
I am sending installation guide valid for FLEXNet 11.11.1 license manager available on Creo Parametric 3.0 DVD, because(unfortunatelly) I do not have similar guide for FLEXNet license manager available on Creo Parametric 1.0 DVD. I hope it can help you.
MH
Martin Hanák
Thank you very much, i hope after that the programe works.
