Major dwg issues with embedded objects (pictures). Functionality: FAIL.
Ok, so, when PT C announced that you can embed pictures in a dwg, I was happy.....until I actually tried to USE that (non)functionality. Frankly, it's horrible. It's almost impossible to work with, and when I had to embed the pictures as Word files, then it decides simply NOT so show the pictures. They still show up in the Dwg Tree as "objects", but they have disappeared. I "open" them, to find everything all screwed up in the word document. I fix it there and save it, and it does nothing. I try and "edit" it, and it's almost impossible to edit, and then nothing I do works anyways.
I'd have to rate this (non) functionality a -10 on a scale of 1 to 10. MAJOR FAIL.
Anyone else have these issues or any tricks they'd like to share?
Thx!
