Hi all,
I'm trying to mate two different component inside an assembly using VB.Net API. I found the example inside the official documentation (vbapi_examples) and everything works fine.
Here is the code:
'Assembling Components
'Function : assembleByDatums
'Purpose : This function demonstrates how to assemble a component
' into an assembly, and how to constrain the component
' by aligning datum planes. If the complete set of datum
' planes is not found, the function will show the
' component constraint dialog to the user to allow them
' to adjust the placement.
Public Sub assembleByDatums(ByRef session As IpfcBaseSession, _
ByVal componentFileName As String, _
ByVal assemblyDatums() As String, _
ByVal componentDatums() As String)
Dim model As IpfcModel
Dim assembly As IpfcAssembly
Dim modelDesc As IpfcModelDescriptor
Dim componentModel As IpfcSolid
Dim asmcomp As IpfcComponentFeat
Dim constraints As IpfcComponentConstraints
Dim i As Integer
Dim asmItem As IpfcModelItem
Dim compItem As IpfcModelItem
Dim ids As Cintseq
Dim path As IpfcComponentPath
Dim asmSelect As IpfcSelection
Dim compSelect As IpfcSelection
Dim constraint As IpfcComponentConstraint
Dim errorCount As Integer
Try
'Get the current assembly and new component
model = session.CurrentModel
If model Is Nothing Then
Throw New Exception("Model not present")
End If
If (Not model.Type = EpfcModelType.EpfcMDL_ASSEMBLY) Then
Throw New Exception("Model is not an assembly")
End If
assembly = CType(model, IpfcAssembly)
modelDesc = (New CCpfcModelDescriptor).CreateFromFileName(componentFileName)
componentModel = session.GetModelFromDescr(modelDesc)
If componentModel Is Nothing Then
componentModel = session.RetrieveModel(modelDesc)
End If
'Package the component initially
asmcomp = assembly.AssembleComponent(componentModel, Nothing)
'Prepare the constraints array
errorCount = 0
constraints = New CpfcComponentConstraints
For i = 0 To 2
'Find the assembly datum
asmItem = assembly.GetItemByName(EpfcModelItemType.EpfcITEM_SURFACE, _
assemblyDatums(i))
If asmItem Is Nothing Then
errorCount = errorCount + 1
Continue For
End If
'Find the component datum
compItem = componentModel.GetItemByName(EpfcModelItemType.EpfcITEM_SURFACE, _
componentDatums(i))
If compItem Is Nothing Then
Continue For
End If
'For the assembly reference, initialize a component path.
'This is necessary even if the reference geometry is in the
'assembly
ids = New Cintseq
path = (New CMpfcAssembly).CreateComponentPath(assembly, ids)
'Allocate the references
asmSelect = (New CMpfcSelect).CreateModelItemSelection(asmItem, path)
compSelect = (New CMpfcSelect).CreateModelItemSelection(compItem, Nothing)
'Allocate and fill the constraint
constraint = (New CCpfcComponentConstraint).Create _
(EpfcComponentConstraintType.EpfcASM_CONSTRAINT_ALIGN)
constraint.AssemblyReference = asmSelect
constraint.ComponentReference = compSelect
constraints.Insert(constraints.Count, constraint)
Next
'Set the assembly component constraints and regenerate the assembly if
'atleast one constraint has been defined properly
If errorCount < 2 Then
asmcomp.SetConstraints(constraints, Nothing)
assembly.Regenerate(Nothing)
session.GetModelWindow(assembly).Repaint()
End If
'If any of the expect datums was not found, prompt the user to constrain
'the new component
If errorCount > 0 Then
MsgBox("Unable to locate all required datum references." + _
"New component is packaged")
asmcomp.RedefineThroughUI()
End If
Catch ex As Exception
MsgBox(ex.Message.ToString + Chr(13) + ex.StackTrace.ToString)
Exit Sub
End Try
End Sub
In the example I set the constrain between Planes (TOP, SIDE, FRONT) of the main assembly and the same plane of the new inserted part.
I need to set constrain between the last part of the assembly and the new inserted one but I can't find the way to do that. Can somebody help me?
Have a good day !
Michele
