Hi everybody,
I'm new at this topic, so this is some newbie question. I want to know, how to use Actionlisteners. So i added a same example. There is a tester-class and beneath user_initialize(){} is the OnAfterModelDisplay methode. In user_initialize() i tried different things to get any respone in Creo. I thought i have to take something like the pointer wSession and call addactionlistener with a smartpointer to a Listener (what ever a listener is?!). But nothing worked.
The same problem i have with the other Actionlisteners, which need a methode-call addactionlistner.
Can somebody help me at this point and show me the right direction please. i really want to understand the whole concept of this. thank you!
<inculdes>
class tester : public pfcSessionActionListener
public:
tester(){} //default constructor
void OnAfterModelDisplay();
extern "C" int user_initialize(
int argc,
char *argv[],
char *version,
char *build,
wchar_t errbuf[80])
try
pfcSession_ptr Session = pfcGetProESession ();
wfcWSession_ptr wSession = wfcWSession::cast (Session);
wSession->AddActionListener(smartpointer to Listener );
return (wfcTK_NO_ERROR);
void tester::OnAfterModelDisplay()
try
//do something great
tester class should be extending pfcDefaultSessionActionListener (#include "pfcSession.h").
Otherwise you'll have to implement all methods even unused ones because pfcSessionActionListener class contains only pure virtual methods - this is C++ , nothing to do with OTK.
Pure virtual method :
virtual void Foo() = 0;
is not an empty function (method) :
virtual void Foo() {;}
HIH.
FV.
@michi wrote:
Thank you for your answer!
The thing is, that i can't use
pfcActionListener_ptr listener = new tester();because visual studio throws an error: "the class is abstract"
My understanding was, that the class pfcSessionActionLIstner is an abstract class and it has all actionlistner methods declared as empty functions. Then a user-defined subclass (tester) is defined and inherits everything from "pSAL" and i overload the methods i need in this new class. So my class shouldn't be abstract anymore...
So now i don't know, what i have to do, to get an user-defined class, that's not abstract 😄 Do you see any mistake i make or what thing i didn't understand?
oh and thanks for the information about the xobject. Really appreciate that sort of tips and hints!
First of all, you should not use smart pointers with pfcActionListener otherwise you are for a number of unpleasant surprises. pfcActionListener is inheriting from xobject which is a reference counting 'thingy' from 1990's...
The calling code should be modified like this:
instead of:
should be:
wSession->AddActionListener(listener);
The cleaner approach would be to define pfcActionListener variable as static/global outside of user_initialize(). This would allow to call something like this from user_terminate():
wSession->RemoveActionListener( g_LISTENER)
g_LISTENER = NULL;
HIH.
FV.
@michi wrote:
Hi everybody,
<inculdes> class tester : public pfcSessionActionListener { public: tester(){} //default constructor void OnAfterModelDisplay(); }; extern "C" int user_initialize( int argc, char *argv[], char *version, char *build, wchar_t errbuf[80]) { try { pfcSession_ptr Session = pfcGetProESession (); wfcWSession_ptr wSession = wfcWSession::cast (Session); wSession->AddActionListener(smartpointer to Listener ); return (wfcTK_NO_ERROR); } } void tester::OnAfterModelDisplay() { try { //do something great } }
HIH.
FV.
Thank you very much! learned a lot.everything works great.
After testing i read the user guide again. Now i get it. The pfcactionlistner (of course the one i want to use) class is the base class and there is also a pfcdefaultactionlistner class, which sub-classes the pfcactionlistner-base-class. and in this class there are all methodes implemented emtpy. So i don't have to do that in my code.
