Need API Suggestion to use Creo UI Analysis >> Measure >> Summary
sri_kayala
I am using Creo Parametric 4.0 M140
Please suggest the below Creo UI workflow in toolkit API
1. Analysis >> Measure >> Summery >> Select CSYS at assembly level >> Get info X,Y,Z.
@sri_kayala,
To get a matrix of component use API ProAsmcomppathTrfGet(). This function could return the Matrix in both directions depending on arguments:
ProAsmcomppathTrfGet (
 ProAsmcomppath* p_path
 /* (In)  The component path.
 */ ProBoolean bottom_up  /* (In)
If you request the transformation from the member to the assembly, this is PRO_B_TRUE. Otherwise, this is PRO_B_FALSE. */
 ProMatrix transformation
 /* (Out)
 The transformation matrix.
