Pattern Table Toolkit
Marcusanthony
Is it possible to import datum points  in Creo model  stored  in .pts format file using Creo Toolkit C++ Programming.
Which functions and libraries can be used to import it.
TIA.
tbraxton
(To:Marcusanthony)
Creates a new object representing the PTS file from which to create an import feature.
Class wfcIntfPTS (ptc.com)
Involute Development, LLC
Consulting Engineers
Marcusanthony
(To:tbraxton)
Thank You for your reply.
Do we need to use object toolkit only for this or this can be achieved using protoolkit C++ programming.
tbraxton
(To:Marcusanthony)
The function call I posted is from this subsection of the help files: The Creo Object TOOLKIT C++ APIWizard (ptc.com)
