Pro-Process [using "replace" on sub assm]
TouFueYang
I'm having a hard time figuring out how to use replace in pro-process so I can make multiple process assemblies by recopying & renaming the completed one and just replace the sub assm that changed for the next option of my process model.
ex: completed: assembled with sub A B C
recopy and rename. New assembly is with sub A B D
want to use replace on C and put in D.
Any help would be greatly appreciated.
tou.yang@manitowoc.com
I am sure copy pasting of process steps is not possible. I select the similar parts in one step. I do not know whether UDF options will help.
Hi Amarnath...
This was a very stale post from Toe Fue Yang. It dates back to August 2010 so he may have already resolved the issue.
Thanks!
-Brian
