Pro/toolkit : ProAssemblyAutointerchange() function?
StefanoTaverna
3-Newcomer
Hello All
I'm trying to use the ProAssemblyAutointerchange() function to replace a family table istance in an assembly model but I get a PRO_TK_GENERAL error.
Has someone used this function?
thanks in advance.
here my code :
ProAssembly _parentasm; /* root assembly */
ProMdl _component; // component under root assembly
ProFeature feat; // component feature (old component)
int *ids; // component identifiers from the assembly
ProName istname; // new istance name
ProFamtable ftab; // family table
ProFaminstance fist; // new family table istance
ProMdl newmdl; // new model
ProError err;
ProName tmpname;
int i,psize;
// retrieve new component from family table
err=ProFamtableInit(_component,&ftab);
if ( err!=PRO_TK_NO_ERROR) ....
err=ProFaminstanceInit(istname,&ftab,&fist);
err=ProFaminstanceRetrieve(&fist,&newmdl);
// debug info
ProMdlNameGet(_parentasm,tmpname);
printf("Assembly = %ls\n",tmpname);
ProMdlNameGet(_component,tmpname);
printf("Old Model = %ls\n",tmpname);
ProMdlNameGet(newmdl,tmpname);
printf("New Model = %ls\n",tmpname);
// component id array
err = ProArrayAlloc (0, sizeof(int), 1, (ProArray*)&ids);
err = ProArrayObjectAdd((ProArray*)&ids,PRO_VALUE_UNUSED,1,&(feat.id) );
// debug component id info, (it displays the right internal feature id)
err = ProArraySizeGet((ProArray)ids,&psize);
for ( i=0 ; i<psize ; i++ )
printf("id = %d\n",ids[i]);
// replace the componente (HERE I GET THE ERROR!)
err = ProAssemblyAutointerchange( _parentasm , ids , newmdl );
// free resource
ProArrayFree((ProArray*)&ids);
Your code works fine , just ensure you add valid and correct feature Id in API
It appears feature object is not initialized , so feature Id will be a garbage value.
Hi
I find out the issue: the model had regeneration problems, I fixed the errors moving the cursor under the component feature, after that it works fine.
