Pro toolkit
cshah
Pro toolkit
Hello All,
After registering Auxiliary application in Creo 2.0 when I click on Start button it give me an error
"Creo registry file protk.dat : appliation failed to start"
I have correctly kept path for Text Folder and dll file location in protk.dat file.
Any help greatly appreciated....Thanks....
sully7
(To:cshah)
Hey Chirag,
This typically is related to your code. Do you have your user_initialize() and user_terminate() functions defined properly? Also, are you using an Asyncronous or Syncronous environment? I typically use the following format for syncronous DLLs:
extern "C" {
int user_initialize();
int main(int argc, char *argv[]);
void user_terminate();
// Initialize Toolkit Environment
ProToolkitMain (argc, argv); // Syncronous
return 0;
// Do some stuff
return(0);
return ;
Sully
President & Founder
CadActive Technologies - www.cadactive.com
cshah
(To:sully7)
Hello Sully,
Thanks for your reply.
I have defined user_initialize() and user_terminate() functions properly.
I am using Syncronous environment.
Can you please give me your Email Id so that I can share it with you.
Chirag Shah
Hi
Do you've properly set your Environmental Variables?
Parthiban Kannan
href="https://www.linkedin.com/in/parthiban-kannan/" target="_blank"
