ProMdlUnitsCollect example
JohnMattson
I'm trying to use the function ProMdlUnitsCollect to ultimately retrieve
whether the mass units are LB or KG. My code compiles, but the function
keeps failing. I suspect because of he 3rd parameter. This is what I
have.
ProMdl model;
ProUnitType unit_type = 1;
ProUnititem *unit_items;
status = ProMdlUnitsCollect(model, unit_type, unit_items);
Does anyone have any help or examples for using this function?
Thanks, John
Function ProMdlUnitsCollect
Retrieves the units available to the model.
Synopsis
#include <promdlunits.h<br/><file: c:\ptc\wf4\prom100\protoolkit\protkdoc\api\promdlunits_h.html=">
ProError
<file: c:\ptc\wf4\prom100\protoolkit\protkdoc\api\protoolkiterrors_h.h<br="/>tml#ProError>
ProMdlUnitsCollect
ProMdl
<file: c:\ptc\wf4\prom100\protoolkit\protkdoc\api\proobjects_h.html#pr<br="/>oMdl> mdl
/* (In)
The model handle.
ProUnitType
<file: c:\ptc\wf4\prom100\protoolkit\protkdoc\api\promdlunits_h.html#p<br="/>roUnitType> type
/* (In)
The type of unit to retrieve.
ProUnititem
<file: c:\ptc\wf4\prom100\protoolkit\protkdoc\api\promdlunits_h.html#p<br="/>roUnititem> ** units
/* (Out)
ProArray
<file: c:\ptc\wf4\prom100\protoolkit\protkdoc\api\proarray_h.html#proa<br="/>rray> of units. Free this array using ProArrayFree
<file: c:\ptc\wf4\prom100\protoolkit\protkdoc\api\105.html="> ().
This electronic message including any attachments ("Message") may contain information that is privileged, confidential and/or exempt from disclosure under trade secret and other applicable law. If you are not the intended recipient, notify the sender immediately, permanently delete all copies of this Message, and be aware that examination, use, dissemination, duplication or disclosure of this Message is strictly prohibited.
5 REPLIES 5
You should be passing address of unit_items.
status = ProMdlUnitsCollect(model, unit_type, &unit_items);
Hope this works.
Vinay
2009/12/15 John Mattson <->
> I’m trying to use the function ProMdlUnitsCollect to ultimately retrieve
> have.
> ProMdl model;
> Thanks, John
> *Function ProMdlUnitsCollect*
> *Synopsis*
> #include <promdlunits.h>
> ProError
> *ProMdlUnitsCollect*
> ProMdl *mdl*
> /* (In)
> The model handle.
> ProUnitType *type*
> /* (In)
> ProUnititem** *units*
> /* (Out)
> ProArray of units. Free this array using ProArrayFree().
John,
You are correct that the 3rd parameter is incorrect. You need to be passing a pointer pointer (**) for the third parameter. You have correctly declared the unit_items as a ProUnititem * but you need to pass the address of unit_items to the function. Try the following:
Patrick Williams
Patrick,
Thanks that did the trick. What I'm ultimately trying to do is report
back whether the mass is LB or KG. So if I set the unit_type=1 (which
is PRO_UNITTYPE_MASS), should unit_types then contain the LB or KG
information I'm looking for? The following code keeps print 3LBM even
if I change the units to KG.
ProCharName unit_name;
ProWstringToString(unit_name, unit_items);
sprintf(logbuff, "Unit name is: %s\n", unit_name);
Thanks, John
John,
You are missing what the function ProMdlUnitsCollect is actually doing. Follow these steps:
1. Call ProMdlUnitsCollect to retrieve an ARRAY of ProUnititems.
2. Loop through each ProUnititem.
3. Print out the ProUnititem[i].name.
4. Free the ARRAY of ProUnititems by calling ProArrayFree or else you will leak memory.
Patrick Williams | Engineering Systems | Sr. Applications Engineer | Steelcase Inc. | 616.698.4078
[cid:image001.jpg@01CA7FCF.2F960880]
Function ProMdlUnitsCollect() returns all the units available to a model.
To get unit assigned to model, functions ProMdlPrincipalunitsystemGet() and ProUnitsystemUnitGet() can be used.
E.g.
ProMdl model;
ProUnititem *mass_unit_items;
int iMassUnits = 0;
ProUnitsystem model_unit_system;
ProUnititem model_mass_unit;
ProCharName cMassUnitName;
// Get current model
ProMdlCurrentGet(&model);
// Collect all units avaliable to model for mass
ProMdlUnitsCollect(model, PRO_UNITTYPE_MASS, &mass_unit_items);
// Display information
ProArraySizeGet(mass_unit_items, &iMassUnits);
ProMessageDisplay(L"umsg.txt", "USER %0s", "Mass units available to model: ");
ProMessageClear();
for(int i=0; i<imassunits; i++)<br="/>{
ProWstringToString(cMassUnitName, mass_unit_items[i].name);
ProMessageDisplay(L"umsg.txt", "USER %0s", cMassUnitName);
ProMessageClear();
// Free allocated memory
ProArrayFree((ProArray *)&mass_unit_items);
// Get principal system of units currently assigned to the model
ProMdlPrincipalunitsystemGet(model, &model_unit_system);
// Get mass unit from principle system of units
ProUnitsystemUnitGet(&model_unit_system, PRO_UNITTYPE_MASS, &model_mass_unit);
ProWstringToString(cMassUnitName, model_mass_unit.name);
ProMessageDisplay(L"umsg.txt", "USER %0s", "Mass unit assigned to model: ");
ProMessageClear();
ProMessageClear();
Output:
lbm
kg
g
mg
tonne
ounce-m
slug
ton-m
IPS_mass_unit
lbm
Amar Junankar
Sr. Application Engineer
Imagecom, Inc.
www.aspire3d.com
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
