Hi every TK user,
I got a big trouble when i used the ProSelcet function to select geometry item.
the problem is " when i first time call the fucntion ProSelcet ,the selection object is store in <p_select_1>, but the second time call the fucntion ProSelcet,the selection object not only store in <p_select_2> also store in <p_select_1>."
the first selection object in <p_select_1> was overwrited by second selection object .
do anyone know what's wrong with this problem?
Hope someone can help me,thanks.
code:
ProSelection *p_select_1,*p_select_2;
int n_select_1,n_select_2;
err=ProSelect ( "surface,edge", 1, NULL, NULL,NULL, NULL, &p_select_1, &n_select_1);
err=ProSelect ( "surface,edge", 1, NULL, NULL,NULL, NULL, &p_select_2, &n_select_2);
API information says
p_sel_array - A pointer to an array of
<i>ProSelection</i> structures. This
argument points to static memory allocated by the function.
It is reallocated on subsequent calls to this function.
Memory will be reallocated. you can convert the Proselection to surface or edge and save it in vector before calling next time Proselect.
Also try once using ProSelectionCopy()
you have to use ProSelectionAlloc() ?
I don't use it.
I think ProSelectionAlloc() is convert <ProModelitem> to <ProSelection>.
But, in here, ProSelect get data type is <ProSelection> which is i want, so i don't need ProSelectionAlloc,ringt?
thank you for your reply.
After using ProSelect(), I ues ProSelectionCopy() save the selection object.
it's work, can help me got the purpose.
I do not think that your code:
ProSelection *p_select_1,*p_select_2; int n_select_1,n_select_2; err=ProSelect ( "surface,edge", 1, NULL, NULL,NULL, NULL, &p_select_1, &n_select_1); err=ProSelect ( "surface,edge", 1, NULL, NULL,NULL, NULL, &p_select_2, &n_select_2);
should cause a problem.
OK ,What could be the reason then:
- more trival option but want to mention here is to check if your program is compield and linked with the correct options - to verfiy if you compiled the Toolkit program correct /spawn,dll or asyncronous mode / with the correct setting - a test could be done if you use some code in the ptc examples and call you code from there. Example:
...Common Files\protoolkit\x86e_win64\obj\protk_install_example.zip
- what I think the problem what you mention is caused anywere later in your code where you override the one handle by the other...
- for ProSelect you DO not need to allocate memory for the ProSelection handle.
Here an example what I extracted (error handling also removed) from a working program for UDF creation:
#include <ProSelection.h>
int n_sel;
ProLine wPrompt;
ProMdl part_mdl;
ProSelection *sels_surface,*sels_surface,SelRefAxis;
ProModelitem pModelitem;
ProUdfdata udf_data;
ProUdfreference reference = NULL;
status = ProSelect("axis", 1, NULL, NULL , NULL, NULL,&sels_axis, &n_sel);
if (status != PRO_TK_NO_ERROR || n_sel != 1)
return PRO_TK_GENERAL_ERROR;
status=ProSelectionCopy (sels_axis[0], &SelRefAxis);
status=ProSelectionModelitemGet (sels_axis[0], &axis_item);
status = ProSelect("surface", 1, NULL, NULL , NULL, NULL,&sels_surface, &n_sel);
if (status != PRO_TK_NO_ERROR || n_sel != 1) return PRO_TK_GENERAL_ERROR;
status=ProSelectionModelitemGet( sels_surface[0], &pModelitem )
status=ProModelitemMdlGet (&pModelitem, &part_mdl);
ProStringToWstring(wPrompt , "Platzierungsachse / Placement Axis" );
status=ProUdfreferenceAlloc (wPrompt , SelRefAxis /*sels_axis[0]*/ , PRO_B_TRUE , &reference));
status=ProUdfdataReferenceAdd (udf_data, reference);
-Roland
the problem not caused by later code.
i debug my code. when the code run to second ProSelect() ,the <p_select_1> was override by second selection object immediately.
i think the problem is caused by Syalagudri mention :
argument """"points to static memory""""" allocated by the function.
so i use ProSelectionCopy() to save ProSelect() seletion object.
thank your reply.
