Hello everyone,
years ago using Creo2, i was able to use JLINK, now that I switched to Creo 9.0.2.0 I don't even know how to install it.
From the installation setup of Creo 9.0.2.0 I can't even find it.
I tried to install all the setup "Toolkit API" options, but in the Creo 9.0.2.0 installation folder I can't find any "jlink" directory.
Can anyone help me, I'm a beginner.
Thank you.
Hello
The folder is now called "OTK"
Remember after 5.0.4.0 (as I remember) you need to install an external JRE, and you have different versions to select.
Allan
Hello
Allan
