Re-Activate Ribbon menu function
ptc-4809772
3-Newcomer
Good morning everyone,
I'm using Creo 10 and from the "Tools" ribbon menu I start my c# application.
We can do everything but in the "Model" menu a lot of function are disabled especially "Parameters". I don't understand why this happen when we start our application and from that application we are able to delete all the custom "Parameters".
When we close our app I thought the menu will be active again but this doesn't happen and if I do a right click in the assembly I have the icon for "Activate" it.
I tried these option:
https://www.ptc.com/en/support/article/CS288287?_gl=1*1b9p919*_ga*MTIyMzg5NjExOS4xNjg2MTI0MTUx*_ga_1QBT6P6HR1*MTY4NzUwNDM2My4xMS4xLjE2ODc1MDU1NzguMC4wLjA.
https://community.ptc.com/t5/Customization/Get-the-model-handle-for-the-activate-component-in-the-current/td-p/387940
ProAsmcompConstrRedefUI()  - https://community.ptc.com/t5/Customization/activate-sub-assembly-using-toolkit/m-p/570117/highlight/true#M7653
But nothing is working. I have to close the file and open it again to check the "Parameters".
How can enable, with ProToolkit API, the menu during Close function of my application?
Thanks a lot,
Nicola
RPN
(To:ptc-4809772)
It is hard to tell, my guess would be, that you closed a window, which was activated by your code. In that case you must activate the current window by using CTRL-A. You can save the current window ID, and restore it on app exit,
RPN
(To:ptc-4809772)
ptc-4809772
3-Newcomer
(To:RPN)
I already tried with restore window ID () and was not working.
Today I try again only with this API function:
ProError status;
int window_id;
status = ProMdlWindowGet(curModel, &window_id);
status = ProWindowActivate(window_id);
This it's working good. Re-enable the ribbon menu and I can check the "Parameters".
