Restricted parameters & Pro/Program
dm-3
Hi all,
I have a part with instances created using a family table and I used that part file in an assembly.
I had created a string parameter which is restricted and this parameter holds names of instances.
I want to automate the replacement of part within that assembly and I used Pro/Program for automation.
My problem is when I regenerate the component is not getting replaced for the parameter value. Am getting below mentioned error.
'3205021-OUTER-TUBE-2' cannot be retrieved.
Pro/Program replace of component 3205021-OUTER-TUBE (M40) failed in Assembly SAMPLE.
Aborting regeneration due to failures executing Pro/Program.
Guide me to solve this..
Dhinesh
dm-3
(To:dm-3)
Note
Outer tube is the part & SAMPLE is the assembly.
Dhinesh
Did you ever solve this problem? I know the topic is almost four years old, but I am experiencing a similar issue.
dm-3
(To:ptc-5470038)
I solved this. But If you can post your question let me have a look to resolve.
rakalawadi
2-Explorer
(To:dm-3)
Let's say you have a family table with 2 instances: instance1, instance2.
In your assembly, install only the first one.
Create an integer pivot parameter, let's call it "param_a" and set the value 1 for it.
In relations create the decisions staements. Here is an example:
if param_a == 1
comp = "instance1.prt"
else
comp = "instance2.prt"
endif
Now, in Pro/Program identify the statements where you want to interchange your instances. You should find something similar with this:
ADD PART INSTANCE1
INTERNAL COMPONENT ID 24
PARENTS = 22(#6)
END ADD
and modify them in the following way:
ADD COMPONENT (COMP)
PARENTS = 22(#6)
END ADD
Now, If you change the value of your "param_a" from 1 to 2, the program will automaticaly exchange the instances in your assembly.
You must be careful if you rename your instances, because the rename procedure will not rename the names of the instances in your relations! You must update manualy the names stored in relations. This is the only negative point for this method.
Good luck
pjablonski
(To:dm-3)
why don't u use "lookup_instance"
