Windows does things differently when apps are run through the task manager.
You do not have any mapped drives, etc.
Take that into account in your application.
Can you explain for what purpose you need to run Windchill/Creo as a task?
I want Creo to process a batch of files and report symbols that occur on drawings. Since there are many files (1000's), I thought it would be best to start Creo, process say 20 drawings, and then restart and cleanup the cache. This way there should not be any problems caused by disk space or full memory.
Not sure, but couldn't you just clear the memory after certain number of files instead of restarting Creo?
Automate:
File
Manage session
Erase Not Displayed
I used a trail file to run through hundreds of drawing files in order to generate DXF files. This was all done in one session. The trick is exactly what was suggested; to close all the opened files, then use
File->Manage Session->Erase Not Displayed
after each file was processed. Otherwise you'd hit a limit on opened files, or other undesirable failures. The only inescapable problems were the files that were saved in an incomplete or failed state by whoever created them.
Erase Not Displayed command does not free RAM as expected. If you run a trail file that repeats a certain operation for 1000 files, you will see that the RAM keeps growing even if Erase Not Displayed command is applied.
That's dissapointing. Then what purpose does the erase no displayed command serve, I wonder? I guess it shortens the "In Session" model list, but I was always under the assumption that it was freeing up memory from large models I no longer am working with.
yes, that's dissapointing. But that's how it works.
For sure the memory which is allocated gets freed, but due to the fact that PTC is actively managing the memory by themselves, you will not see this. If you would write an application like Creo you would do this as well. Once you have the memory, reuse it, don't give it away to the OS. That means, erase not display, is still recommended 🙂 if you open hundreds of files and work on it. But even this has limitations and you may crash 🙂
You can’t start Creo in that way, either with parametric.exe plus psf or just start the batch, The Creo exe is since years the xtop.exe, no idea why this was never changed. And yes g:no_graphics -i:rpc_input this args are required as well. This args must be given to the xtop. If you just start the parametric.exe you need to know which keys you want to use. Try it by yourself.
login to PTC Support and use following link
https://www.ptc.com/en/support/search/#q=g%3Ano_graphics
In CS300745 I found following information ...
Creo Parametric when launched with -g:no_graphics is made to run a trail file
This means you can:
1.] generate trail file
2.] run batch file containing parametric.exe -g:no_graphics PATH_to_trail_file
@MartinHanak @your answer is off topic, he tries to create an asynchronous session, and this does not work because the specified Creo command is invalid, as far I can see.
create batch file to open the creo. and call this batch file in the Task sheduler with repeat interval timings , and set it dont start a new instance.
