Any ideas how to disable this please
What do you mean? Do you want to set the position to (0,0)?
I don't know what it is. I would prefer it not to show on launch of creo.
rename all config.pro files to config.pro_renamed and start Creo.
how does renaming my config file fix this please.
if you use Creo Parametric then renaming config.pro will tell you whether the problem is "hidden" inside config.pro.
Same problem. What is this box for
I use Creo Parametric for ages and have never seen such dialog box. What Creo Parametric version do you use? Please attach pictuire of its window.
5.0.4
@RH_10122575 wrote:
5.0.4
you picture tells that your Creo installation is customized somehow. Therefore to resolve your problem you have to contact a person who did installation.
The last place for check are you environment vars, maybe there is a different between the default ones, open cmd shell and enter set, or the ones in Creo, open a system window and enter set as well.
Check for proTk.dat and creoTk.dat as well, because your hitachi env is not the default one 🙂
