Hello everybody,
I set up the graphics_library_dir config.pro line to customize the Appearance Library in Creo Parametric 7.
When I go into the aspects, the personal ones are all dark and the bookcase does not show any aspects.
The customized folder and sub-folder structure is exactly the same as the standard files that are in Coommon Filles etc.
Is there a way to set a different one? (see images 1, 2 ,3)
Matteo
A quick search led me to a more useful description than the one line the Creo options gives:
Valid path
Allows you to specify a different location for the graphic-library directory. This directory contains the system libraries for scenes and appearances and is available, by default, in the <loadpoint> directory. To change the location of this library, set graphics_library_dir to the required directory. For example, if the graphic-library directory is available in C:\ptc\graphiclib\graphic-library , set graphics_library_dir to C:\ptc\graphiclib .
The graphic-library directory must contain the following subdirectories:
textures for appearance placement editor system libraries with image files.
materials for Appearance Gallery and Appearances Manager system libraries with appearance files (.dmt) that are organized in subdirectories based on appearance classes.
adv_material containing advanced appearance libraries that are organized in subdirectories based on appearance classes.
HDRI directory with HDRI files (.hdr) .
scenes for the default gallery (.scn) for the Scene tab in the Scenes dialog box.
So judging from what you have in the two screenshots 1.png and 2.png perhaps your specification in the config.pro should be:
graphics_library_dir c:
since the option parameter is telling Creo where the top level directory "graphics-library" is located.
Valid path
