Sheetmetal K & Y Factor
Doss
Folks
Anyone of you had sucess in the past retriving K factor & Y factor values from sheet metal model or drawings using Pro/Toolkit API.
Please suggest
Regards
Doss
pwilliams-3
(To:Doss)
Doss,
I had a great response already typed up for you but after a bit more research I found out that those parameters are not owned by any ProModelitem object that I could think of from which to access the parameters. I think you should contact PTC TS.
Patrick Williams | Engineering Systems | c: 616.947.2110
[cid:image002.jpg@01CE815E.AF2D65E0]
