Start and end point of an arc in toolkit
SN_10773997
How can I get the start and end point (as a pfcPoint3D_ptr) using a pfcArcDescriptor_ptr object in object toolkit c++?
Hi @SN_10773997,
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Best regards,
Catalina
PTC Community Moderator
PTC
RPN
(To:SN_10773997)
It seems no one is willing, so here to get a clue for Toolkit,
You may have an edge or a curve. For a curve
    err= ProCurveInit(model,geom_id,&p_curve_data);
    err = ProCurvedataTypeGet(p_curve_data, &c_type);
    switch(c_type)
    case PRO_ENT_ARC:
	err = ProArcdataGet(p_curve_data, v1, v2, p1, &st_a, &en_a, &rad);
/* or
dataPtr->data.p_curve_data->arc.vector1[0] and 1 and 2
dataPtr->data.p_curve_data->arc.vector2[0] and 1 and 2
dataPtr->data.p_curve_data->arc.origin[0] and 1 and 2
dataPtr->data.p_curve_data->arc.start_angle
dataPtr->data.p_curve_data->arc.end_angle;
dataPtr->data.p_curve_data->arc.radius;
Check UtilIntfData.c
For an edge it is similar ....
