How to use the UDF_ORIENTATION in smart assembly? I have the UDF with two orientation
I've tried like this but not working. I don't know what I am missing. can someone help on this?
CREATE_UDF lib:Models\+&FEAT_UDF_NAME MDL_PART
UDF_REF "csys" PART_CSYS
UDF_DIM "distance_x" DIM_X
UDF_DIM "distance_y" -DIM_Y1
UDF_EXP_REF NOTCH_PATTERN FEATURE 0
UDF_ORIENTATION FLIP
UDF_ORIENTATION NO_FLIP
END_CREATE_UDF
I also tried with Interactive that also not working. I am getting error Unable to construct the feature. I usually get the same error in manual mode without FLIP the orientation. So that I concluded the Orientation FLIP not working on my program.
Hi Parthiban,
This is a Toolkit bug that PTC has reported (see this PTC support page).
Until this is resolved in the Toolkit the UDF_ORIENTATION command is unstable. I would suggest that you may need to use interactive in this situation, or re-develop the UDF so that it doesn't require the flip.
Hi Parthiban,
