Using VB API to select CSYS
CADCAMTECH
Dear
Please help me example VB API in Creo
Create a button1 select CSYS in Creo then get name show in textbox1 in VB.
I want to create button in VB so select object in Creo, I had read ptc document but difficult for me to find example.
RPN
(To:CADCAMTECH)
I couldn't resist, in Tcl I need this:
# Assume a 3D model is active,
# and contains only one (to make the result clear) Csys with feature ID 11
# The Csys/Type/Geom ID off the Csys is 58
# No error checking in this code here
# Create Selection Object 'selObj' is the name of the object ps_sel selObj # Now ask the user to select a 'csys' (controls goes to Creo) selObj select csys # back from Creo, get the model item, note you selected a CSYS and not a FEATURE selObj modelitem miObj # Get the CSYS GeomID, after this command, GeomID will hold 58 set GeomID [miObj cget -id] # Get the Feature ID, after this command FeatID will hold the Value '11' set FeatID [ps_geom to_feat_ids CSYS $GeomID]
For the selection only, 2 lines of code Smiley Very Happy
CADCAMTECH
(To:RPN)
Dear Sir
Thanks your reply, I had follow your code but error.
I'm using Visual Basic 2016 Windows form Application not C# (I dont know)
I want to get name CSYS to textbox1
Thanks advance your help
RPN
(To:CADCAMTECH)
That's simple, you have the model handel, and the feature ID, now you can get the feature name with this two references. In Tcl, working on the current model:
# Get the Feature Name
set FeatName [ps_feat name $FeatID]
CADCAMTECH
(To:RPN)
Dear Sir
Can you help more detail
I don't want feat ID,
I just want create a button in VB API => then select one of any Csys in Creo => then get name to textbox1 in VB API
RPN
(To:CADCAMTECH)
Hello CCT, no I will and I can't provide a VB script, because I don't use VB, it's hard to read for me and you need to write so much code. I did it with Tcl, on the fly (All options need a leading '-' 🙂   )
Now have fun with VB!
proc Init {} {
	# Destroy for ReRun, else on ReRun an error would generated
	destroy		.ptc
	ps_destroy	miObj selObj
	# Main Window
	toplevel		.ptc
	# Place it
	wm geom .ptc -400+200
	# Button and Entry with text a global variable
	pack [button .ptc.b1 -text "Select CSYS" -command SelectAndUpdate]
	pack [entry  .ptc.e1 -textvar NAME_OF_MODELITEM -width 35 ]
	# Craete modelitem and selection Object/Command, selObj will reference the miObj
	ps_modelitem 		miObj	-update yes
	ps_sel		selObj -modelitem miObj
proc SelectAndUpdate {} {
	# Select the Csys
	selObj sel csys
	# Get the data to the global var ::NAME_OF_MODELITEM this will update the entry value
	set ::NAME_OF_MODELITEM "Name: [miObj cget -name] ID: [miObj cget -id] Type: [miObj cget -type]"
Init
