Hope this hasn't been covered...I found lots of toolkit but no VB.
Is it possible to change the color of a surface using VB/VBA?
I've (I think) managed to "get hold" on the surfaces using this:
Private Function GetSurfaces(ByRef model As IpfcModel)
Dim surfaces As IpfcModelItems
Dim numSurfaces As Double
End Function
Thanks in advance.
There is no API function in VB or Weblink. Available in Toolkit only.
Perhaps you might try this:
Add all your surfaces to the SelectionBuffer with IpfcSelectionBuffer.AddSelection().
Then run a macro/mapkey with session.RunMacro().
You might have colors defined in your environment and these colors have a NAME, for example "r1", so this mapkey executed after adding surface selections to the selection buffer willassignthe color r1 to the surfaces:
mapkey _sc ~ Select `main_dlg_cur` `ProCmdViewGallery.view`;\
mapkey(continued) ~ Select `main_dlg_cur` \
mapkey(continued) `ProCmdViewGallery_layoutph.palette_holder.myAppPalette.NamesList`1 `r1`;\
mapkey(continued) ~ Timer `UI Desktop` `UI Desktop` `Gallery_UI_Timer`;\
mapkey(continued) ~ Close `main_dlg_cur` `ProCmdViewGallery.view`;
Hope this helps.
Andreas
__________________________________
Andreas Hellmann
MCAD Services Pro/E & Pro/E customization
Am Wartfeld 7
D-61169 Friedberg
phone: +49 151 21259910
mail: -
