See the picture here. We often have a feature parameter in an assembly. That can avoid assigning different parameter for the same components in different assemblies.
Very often we need to change the value of this parameter. I am trying to write a vb.net code to automate the process but cannot find the proper interface, method or function to perform this task.
Can anyone share a hint? Thanks
Configure the model item, the owner is the model, the type is a FEATURE, the ID is the feature id, that’s it. The rest of the calls are the same. I guess there a couple of examples for VB. BTW, you still have to configure the tree, in C I don’t know any API to configure the tree display columns.
Thanks 17-Peridot,
I follow your comments and successfully extract the data.
In case someone else has the same question as mine, I attached my code here for the reference.
Thanks again for 17-Peridot 's help.
Try
' Connect to Creo session
Dim session As IpfcBaseSession = asyncConnection.Session
Dim model As IpfcModel = session.CurrentModel
' Ensure model is an assembly
If model Is Nothing OrElse model.Type <> EpfcModelType.EpfcMDL_ASSEMBLY Then
Console.WriteLine("Please open an assembly in Creo.")
Return
End If
Dim items As IpfcModelItems = CType(model, IpfcModelItemOwner).ListItems(EpfcModelItemType.EpfcITEM_FEATURE)
Dim i As Integer
For i = 0 To items.Count - 1
Dim itemfeature As IpfcFeature = CType(items(i), IpfcFeature)
If itemfeature.FeatTypeName = "COMPONENT" Then
'Console.WriteLine(itemfeature.FeatType & " " & itemfeature.FeatTypeName & " " & items(i).Id)
Dim featParmOwner As IpfcParameterOwner = CType(itemfeature, IpfcParameterOwner)
Dim featParms As IpfcParameters = featParmOwner.ListParams
If Not featParms.Count = 0 Then
Dim TagParam As IpfcBaseParameter = featParmOwner.GetParam("Tag_Number")
If TagParam IsNot Nothing Then
Dim TagParamValue = TagParam.Value
Console.WriteLine(TagParamValue.StringValue)
End If
End If
'Console.WriteLine(featParms.Count)
End If
Next
Catch ex As Exception
Console.WriteLine("Error: " & ex.Message)
End Try
