I've made the conection between vb and creo.
Now I need some help to do the following:
1st I need to save the screen image to a file *.png to a file
2nd If I have an assembly oppened, I need to reed the parameters from the activated part. Not the displayed assembly, but the activated part in the assembly.
Any idea of how to do it?
for 1st question use option IpfcWindow.ExportRasterImage()
for 2nd question, as per my understanding IpfcBaseSession.GetActiveModel() should give the activated model (but not sure). Once you get the model use IpfcParameterOwner.GetParam()
That's it.
It worked 🙂
Could you share the code for exporting as Raster Image? I'm struggling there a bit.
Try this:
Dim conn As pfcls.IpfcAsyncConnection
Dim session
Dim model As IpfcModel
Dim window As IpfcWindow
Private Sub Get_Creo()
Dim asynconn As New pfcls.CCpfcAsyncConnection
'Dim conn As pfcls.IpfcAsyncConnection
Dim session As pfcls.IpfcBaseSession
conn = asynconn.Connect("", "", ".", 5)
session = conn.Session
'model = session.CurrentModel
model = session.GetActiveModel
window = session.CurrentWindow
'mdlname = session.CurrentModel.FileName
mdlname = session.GetActiveModel.FileName
Work_dir = session.GetCurrentDirectory
End Sub
End Sub
That is the code to connect to creo, but I'm looking for Exporting Window as Raster Image. If you could provide that, it would be useful.
sorry, wrong copy paste
Dim instructions 'As IpfcRasterImageExportInstructions
Dim rasterHeight As Double = 2
Dim rasterWidth As Double = 3.85
Dim dotsPerInch As Integer
Dim imageDepth As Integer
Dim bmpInstrs As IpfcBitmapImageExportInstructions
Try
dotsPerInch = EpfcDotsPerInch.EpfcRASTERDPI_100
imageDepth = EpfcRasterDepth.EpfcRASTERDEPTH_24
bmpInstrs = (New CCpfcBitmapImageExportInstructions).Create(rasterWidth, rasterHeight)
instructions = bmpInstrs
window.ExportRasterImage(Work_dir + Nome_imagem + ".bmp", instructions)
Catch ex As Exception
MsgBox(ex.Message.ToString + Chr(13) + ex.StackTrace.ToString)
End Try
If Imagem.Checked = True Then
conn.Disconnect(2)
End If
End Sub
