Is there any type of wait/delay function to Pro Toolkit, or C for that matter?
I am having a situation (and I have in the past) where the dll processing seems to get ahead of the file writing creation routines. And the dll processing can seemingly get ahead of video card regeneration. I admit this is rare, but writing a lot to a loop, the program processing is moving forward. We are talking nanoseconds here but when you are looping and retrieving and exporting, I have had the odd situation where just sometimes exports have been created when drawing dimension have not snapped to snap lines if a parts size was modified and driven by top-down design.
The old Visual Basic had do-events, and VB.net still has Application.DoEvents. for just this reason. IME sometimes with DLL's you just needed this to let different code strings catch up.
No, there is no such a function and there is no need for it. You can use standard C functionality - see for example this: c++ - Sleep for milliseconds - Stack Overflow
Thanks Tomas, looks like just what I needed. Its worth a try for me to see if this helps my situation.
