Hello I need to create new drawing using .frm file using toolkit. I tried API ProDrawingFromTmpltCreate(), but same is not working. This API is working for drawing creation using .drw file. Any thoughts will be of great help. Thanks in advance. Regards Ketan
Your first need to create a drawing by a template and then change the frame .frm. You can do this by ProDrawingFormatAdd(). The easiest way is to use an empty drw, so you don't need to think about pending tables.
Br,
Eike
You need to create it by this way. So I use it in my code and it works. Only other way is to do it by a sync. mapkey. But I wouldn't do it if you don't need it. Whats the feedback of your code? Can you post a sniplet?
There is a PTC example for this (put it in as file).
You need to change the mdl template name to an empty template of your choice.
Br,
Eike
Oh ... I think it's not the same as inside the documentation, but if it works it is a solution : ) It's sometimes that way that you need to check a little bit. Most things are declared perfectly, but sometimes stuff isn't declared that well.
Br,
Eike
