I am using Creo Parametric Release 10.0 and Datecode10.0.3.0
I want to get the tolerance table files which are inside “<Creo Common Files>\tol_tables\iso"
How to get Creo Common File location using PTC pro Toolkit API?
Hi @Praveen2
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
What is a good question?
Thank you for your participation and please let me know if you need further assistance!
Best regards,
To get Creo Parametric built in environment variable CREO_COMMON_FILES (only available from current Creo session):
Details and other workarounds (Windows Registry, Creo support.inf, Session Environment Variable)
Application through Creo Toolkit:
Using Common File is probably not a good idea, I don‘t the exact option name but you can get the path if you read the config option in session .
ProError ProConfigoptSet (ProName option,
ProPath option_value );
and
ProError ProConfigoptionGet (ProName option,
ProConfigoptArrayGet (ProName option, ProPath** value_array);
Purpose: Retrieves the current value for the specified configuration file
option. This function supports multi-string options
(e.g. search_path). Note: Use this function instead of
ProConfigoptGet() while retrieving the value of an option that may
have multiple values or a path-length string.
I‘m sure that there is an option where you can read the tolerance folder from.
