Hello Mr Martin,
Yes with further study of trail files and basic programming, I could successfully extract and modify trail file for .prt import and .stp export for two part files.👍..I could also write a program in Basic to generate trail file. However, just one question is there --
ie how to program to incorporate this line- ~ Input `file_open` `Inputname` `xxxxxxxxxx` into trail file? Sharing trail file and basic program (in .txt format/I had written it in qbasic only, which has been converted to .txt here) herewith.
Requesting for the solution,
Thanks in advance!
please go back to my gentrail_2019-08-30.zip.
gentrail.bas program copies the contents of:
gentrail.bas program ignores step02_body_02.txt file
gentrail.bas program inserts a command between step 2 and step 3:
PRINT #2, "~ Input `file_open` `Inputname` `"; filename$; "`"
This command replaces copying the file step02_body_02.txt.
