import relations
lylebeidler
import relations
WF3 JLink question
How do I add relations to the "Post Regeneration" section of the relations?
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
I should clarifiy - is there somthign I can do in the import relations
instructions that tells it to add the relations to the Post Regeneration
section, instead of initial?
Thanks!
Lyle Beidler
MGS Inc
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
Lyle,
If I remember correctly, the post relations have a relset id of -2. Through
Pro/TOOLKIT, that can be specified. I suspect you can do it through J-Link.
Bob
Bob Monat
Jerand Technical Services, Inc.
bob@jerand.com
www.jerand.com
1-317-875-6087
Sss4598
(To:BobMonat)
Hi BobMonat,
Can you please suggest how can it be done with help of creo toolkit? I want to import relations in model from .txt file using C++ Toolkit.
Thank You in Advance!
Anybody know if this can be done in JLink? I can't find anything in the
JLinkDoc package
Lyle,
Bob
Lyle Beidler
MGS Inc
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
jkent
(To:lylebeidler)
Don't think a method exist to add relations to Post Regeneration
section.
From the WF 4 API,
GetRelations/SetRelations
/*optional*/ stringseq
GetRelations
void
SetRelations
( /*optional*/ stringseq value)
The list of the actual relations assigned to the item.
In case of a Model, this attribute is a complement of
Model.GetPostRegenerationRelations() which contains post regeneration
relations.
Doesn't look like there is a Model.SetPostRegenerateRelations().
