is it available to create parametric sketching (draft entity with references) in drawing?
  • March 10, 2017
  • 0 replies
  • 977 views
I want to create a small circle at the center of the indicated circle or arc.
So, we can check the parametric sketch option, start circle command and add references,then draw the circle.
Then, the small circle is drafted with referecne, and it moves when the reference circle moves.
1, Is this function covered by the protoolkit?
2, Is there ProToolkit function to create "Parametric Sketch"  ?
3, Is there instructions about this in the user guide , help files or  FAQ ?
