jlink asynchronous mode: can't import package
lylebeidler
After writing several synchronous mode JLink apps for Wf3, I'm beginning to
try my hand at an asynchronous app or two.
After copying one of the example files from the tutorial directory &
modifying it, I get a compile error for this line:
import com.ptc.pfc.pfcAsyncConnection.*;
"Package com.ptc.pfc.pfcAsyncConnection not found in import"
So looks like I'm missing something simple - is there a library I need to
copy to my loadpoint or something?
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
Yes, Lyle, you need to add "pfcasync.jar" to your project. It is located at
<load point=">\text\java
Mike Phillips
Sr. Mechanical Systems Technologist
Network Centric Systems
Raytheon Company
+1 (972).344.4056 (office)
6620 Chase Oaks Blvd
Plano, TX 75023-2310
www.raytheon.com
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
