How to stop a macro when you select a value with the right click, then resume the progress of the macro. Example: select a value in the layer tree.
following mapkey works according your needs in Creo 4.0 English.
mapkey lp @MAPKEY_NAMEOpens Layer Properties dialog box;\
mapkey(continued) @MAPKEY_LABELLayer Properties;~ Command `ProCmdLayer_ShowMdlTree` ;\
mapkey(continued) ~ Command `ProCmdMdlTreeShowLyrs` ;@MANUAL_PAUSESelect layer using LMB;\
mapkey(continued) ~ Timer `UI Desktop` `UI Desktop` `popupMenuRMBTimerCB`;\
mapkey(continued) ~ Close `rmb_popup` `PopupMenu`;\
mapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `UIT_TRANSLUCENT` `NEED_TO_CLOSE`;\
mapkey(continued) ~ RButtonArm `main_dlg_cur` `PHTLeft.PHLayerUI.AssyTree` `node0:ANY_LAYER_NAME`;\
mapkey(continued) ~ Command `ProCmdLayer_LayProps` ;\
mapkey(continued) ~ FocusOut `newlayerprops` `LayerNameInput`;
While recording mapkey select Pause to allow for a manual operation/input. You can then type in a prompt to tell the user what to do before resuming the mapkey. Press Resume to continue recording.
Bonjour
Fonctionne pour une boite de dialogue (Exemple: Esquisse) mais pas pour une sélection clic gauche sur un nom dans l'arbre des couches.
Hello
Works for a dialog box (Example: Sketch) but not for a left click selection on a name in the layer tree.
@ddubost wrote:
Hello
please describe in detail what your macro should do.
Attached in detail what wishes to achieve
thank you so much It works perfectly.
Practical question. do you have a solution for a direct recovery with left click selection
I am sorry I do not understand term direct recovery with left click selection. Please explain it in detail.
Do you have a solution for this topic
Sketch dialog box
@ddubost wrote:
thank you for your help and understanding
I do not understand what you mean with the picture
1) I launch the macro
2) I select the layer
3) I click resume
4) The property window is displayed
Possible
- The macro stops without opening a window -
3) The property window is displayed
@ddubost wrote:
1) I launch the macro 2) I select the layer 3) I click resume 4) The property window is displayed
Possible
1) I launch the macro - The macro stops without opening a window - 2) I select the layer 3) The property window is displayed
it looks like you do not want to select layer name, press RMB and click Layer Properties command from context menu.
Try following procedure:
1.] select layer name
2.] run following macro
mapkey lp ~ RButtonArm `main_dlg_cur` `PHTLeft.PHLayerUI.AssyTree` \
mapkey(continued) `node0:ANY_LAYER_NAME`;~ Command `ProCmdLayer_LayProps` ;\
